DHCP option 82 & RADIUS
Hi all!
I suppose to use DHCP option 82 and to control rate-limit of dhcp clients with radius attributes. Now Mikrotik send RADIUS request with option 82 information to billing/radius server. so I trying to setup freeradius…
If anybody use such application? Who has succesful story?
So I already start to join FreeRADIUS to billing system. Mirkotik DHCP server send Radius Access-Request to RADIUS server, but it consider strange password. Where it takes this password ??
the documentation says that password is empty
The router supports an individual server for each Ethernet-like interface. The MikroTik RouterOS DHCP server supports the basic functions of giving each requesting client an IP address/netmask lease, default gateway, domain name, DNS-server(s) and WINS-server(s) (for Windows clients) information (set up in the DHCP networks submenu)
In order DHCP server to work, you must set up also IP pools (do not include the DHCP server’s own IP address into the pool range) and DHCP networks.
It is also possible to hand out leases for DHCP clients using the RADIUS server, here are listed the parameters for used in RADIUS server.
Access-Request:
NAS-Identifier - router identity
NAS-IP-Address - IP address of the router itself
NAS-Port - unique session ID
NAS-Port-Type - Ethernet
Calling-Station-Id - client identifier (active-client-id)
Framed-IP-Address - IP address of the client (active-address)
Called-Station-Id - name of DHCP server
User-Name - MAC address of the client (active-mac-address)
Password - “”
this problem is resolved!!!
Now dhcp clients got ip address depended from its VLAN ( via option 82 and DHCP local relay).
But now I can’t find - how to do ip unnumbered on routeros.
please help
/32 addresses
we use vlan-per-user , DHCP server lease /32 address for every VLAN. but how to setup routing in this case?
I found example for cisco
interface Loopback2
ip address 123.123.123.1 255.255.255.0 ! наша публичная сеть
no ip redirects
interface Vlan555
des Abonent1
ip unnumbered Loopback2
no ip proxy-arp
interface Vlan556
des Abonent2
no ip proxy-arp
interface FastEthernet0/1
des Port Abonenta 1
switchport access vlan 555
switchport mode access
interface FastEthernet0/2
des Port Abonenta 2
switchport access vlan 556
end
ip route 123.123.123.2 255.255.255.255 Vl555
ip route 123.123.123.3 255.255.255.255 Vl556
WHat about mikrotik ?
How do you configure the MikroTik to send option 82 information (Agent Relay Info) to the Radius server?
Thank you in Advance.
If the DHCP server on RouterOS receives option-82 in the request it sends it to the RADIUS server.
actually, if mikrotik received DHCP packet with option82 , it forwards request to RADIUS server with option82 too
