DHCP options in two different tabs
I noticed that DHCP options could be set in two different places.
https://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server
Under DHCP and Networks tabs
Is there any difference if I set the DHCP options in either of the places
The first place only has DHCP option set and the other one has both options and option set
https://net-ship.blogspot.com/2019/10/how-to-setup-dhcp-server-and-ip-pool-in.html?m=1
DHCP Options tab
Is where you add your dhcp options.
DHCP Options set tab
is where you would group options together that are located in dhcp options..
Network/dhcp-options(-set)
Is where you add the options (or sets) you created to the subnet of your choosing.
