When I set that up all “dynamic” clients receives that option (which is quite good), while when I set any client as “static”, and then add that option to client’s config:
Any ideas how to fix that, so ‘static’ assigned client to receive DHCP option(s)? I deploy some ip phones and prefer to reconfigure it with DHCP option 66, and not via visiting each phone web interface (that’s quite slow way).
To be able to find my devices exactly on places it intended to be. In fact, I assign IPs to users dynamically from 192.168.1.100…199, while assign IP to devices statically from 192.168.1.20..99. Easy to maintain, and printers, ip phones etc are always at their places.
Will test, haven’t tried yet.
As I’ve stated, 6.32.4 (“stable” branch). Prefer to stay stable, non needed new features in such a small network.
Of course… what I meant, is why do you set the sip_option on a per static entry basis when you have set it on a per network basis already?
I guess all phones would have a common PBX, so its tidier and more efficient to have just the network entry, that having to maintain each static lease entry.
Of course… what I meant, is why do you set the sip_option on a per static entry basis instead of setting it on a per network basis?
I guess all phones would have a common PBX, so its tidier and more efficient to have just the network entry, that having to maintain each static lease entry.[/quote]
Got your point but I failed to recieve DHCP option in any way, only by setting in in network (the way I did that initially), by setting it in static entry.
Will try to intercept packets but due to network configuration this is a bit hard to do.
You can enable DHCP debug at the router and have a look there.
Do you have another mikrotik device at hand? I’d use it to set a dhcp-client to debug from a client perspective.
Is this a small installation? Good practice for VoIP is having its own network segment (layer 2), and of course its own network range, say 192.168.2.0.
I always setup phones this way, and then set dhcp options on the network dhcp entry.
Sorry about the ROS version, I got mixed up Is firmware up to date?
