DHCP over EoIP
Hello Guys,
I am a new person in the Mikrotik World :slight_smile:
But I am facing the following problems.
We have 2 Mikrotik (same model) on 2 remote site.
I have created an EoIP tunnel between those and it’s working fine.
But I have no idea how can I do that the clients who’s connected to the Site B mikrotik, get IP from DHCP which is a WIN server and located in Site A mikrotik.
I have prepared a short (let’s say) diagram :slight_smile:
https://imgur.com/QFRfqw4
Thank you very much for you help :slight_smile:
Best Regards,
Gabor
Hi, Looking at your Basic diagram it would appear that you intend to create a flat layer 2 network between sites using eoip. For this to work you will have to bridge both ends ethernet and eoip tunnells.
If this is not the case a more detailed diagram would assist.
Just bridge eth3 and EoIP tunnel interface on Tik A and EoIP Tunnel and eth2 on Tik B.
