DHCP over mesh - cant get ip but static works?
I have 2 mikrotik dvices.
both are identical, with wifi 2.4GHz and 5GHz.
DEV1:
1.Create Mesh: Mesh1
2.Add ether1, ether2 wlan1 wlan2 to Mesh1
3.On wlan1 set ap bridge ssid: FOR_PEOPLE_ROOM_1 pass xxxxxxxx
4.wlan2 ap bridge ssid: INTERNAL pass yyyyyyyy
5.wland2 wds: dynamic mesh, wds bridge: Mesh1
6.ARP on Mesh1 enabled
this DEV1 is connected with cable on ether1 to master_router_with_DHCP_SERVER
DEV2:
3.On wlan1 set ap bridge ssid: FOR_PEOPLE_ROOM_2 pass xxxxxxxx
this dev2 is NOT CONNECTED with any cable, it should connect over wlan2 to dev1 wlan2.
When i want to connect to this dev2 with wifi or with cable it does not get ip from DHCP.
When i set static ip address on devices, on smartphone or pc and connect: it works,
but it does not get ip from dhcp.
why?
both /export config
