DHCP_pool
Dear all
i installed mikrotik on my pc and have good control but i have problem on DHCP i using hotspot with one MAC per user when i install mikrotik my lap tob tak ip 253 and the second pc take 252 and so on but if some body connect his pc he take ip and i find lost in this ip
now i want to restore this temporary id taken by unknown user which connet thier pc in any Switch
Hello Ahmed ;
first please write the IP you are using .
second thing you should increase the lease time in the DHCP server , so the server reserve the ip to the same MAC for the lease time you will use .
also from the DHCP-SERVER , leases you could make the ip static .
with this the ip will be fixed with the MAC .
in the same way , when you clear the leases list , the DHCP server will assign new ip’s to the pc’s will connect to the server .
with best regards .
Hi ahmed
thank u for yr interristing
when i open lease list i find all my user and if i find D letter beside user i click it and change it to static to fix user IP but i have never delet this lease only i delete thief users connected via any switch i will delete all lease and reply to u
thanx again my friend and pleased to add u in my messenger
