DHCP problem
Hello all,
I have RB2011UiAS-2HnD installed, simple configuration with all ports tied together via bridge, public WAN (static) IP address, NAT,
and two SSID configured for users (private and guest wireless access).
Everything working fine, except random DHCP server problem.
DHCP server stops leasing addresses, only reboot helps.
Any ideas?
missing:
  • version number you are using
  • export of your configuration, at least he bridge and ip address and dhcp server configuration (/export, preferably NOT a screenshot!)
Hi pe1chI,
thanks for help, config export is attached.
apr/26/2018 10:34:17 by RouterOS 6.41.3
software id = 4V1I-RJTA
model = 2011UiAS-2HnD
serial number = 7A670816B1E2
add name=bridge1
add name=WAN
add name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods=""
management-protection=allowed mode=dynamic-keys name=
"EAA - private" supplicant-identity="" wpa-pre-shared-key=Xxxxxx!
wpa2-pre-shared-key=Xxxxxx!
management-protection=allowed mode=dynamic-keys name="EAA - guest"
supplicant-identity="" wpa-pre-shared-key=Yyyyy wpa2-pre-shared-key=
Yyyyy
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC
disabled=no frequency=2452 mode=ap-bridge security-profile=
"EAA - private" ssid=EAA wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:35:7A:F7
master-interface=wlan1 multicast-buffering=disabled name=
"EAA - guest" security-profile="EAA - guest" ssid=
"EAA - guest" wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add name=dhcp ranges=192.168.0.50-192.168.0.199
add name=dhcp_pool2 ranges=10.10.10.20-10.10.10.199
add address-pool=dhcp disabled=no interface=bridge1 lease-time=1d name=
"EAA - private dhcp"
add address-pool=dhcp_pool2 disabled=no interface="EAA - guest"
lease-time=2h name="EAA - guest dhcp"
/queue type
add kind=pcq name="Guest download" pcq-classifier=dst-address
pcq-dst-address6-mask=64 pcq-rate=1M pcq-src-address6-mask=64
add kind=pcq name="Guest upload" pcq-classifier=src-address
/queue simple
add name="EascCodes - gueet limit" queue="Guest upload/Guest download"
target="EAA - guest"
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=wlan1
add interface=ether1 list=WAN
add address=a.b.c.d/30 interface=ether1 network=a.b.c.d
add address=192.168.0.1/24 interface=ether2 network=192.168.0.0
add address=10.10.10.1/24 interface="EAA - guest" network=10.10.10.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1
add address=10.10.10.0/24 dns-server=10.10.10.1,8.8.8.8,8.8.4.4 gateway=
10.10.10.1 netmask=24
add address=192.168.0.0/24 dns-server=192.168.0.1,8.8.4.4,8.8.8.8
gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=3d max-concurrent-tcp-sessions=50
servers=8.8.4.4,8.8.8.8
add action=drop chain=forward dst-address=192.168.0.0/24 src-address=
10.10.10.0/24
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input connection-state=invalid
add action=accept chain=input protocol=udp
add action=accept chain=input limit=50/5s,2:packet protocol=icmp
add action=drop chain=input protocol=icmp
add action=accept chain=input dst-port=22 protocol=tcp
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input src-address=e.f.g.h/23
add action=accept chain=input src-address=192.168.0.0/24
add action=log chain=input disabled=yes log-prefix="Drop Input"
add action=drop chain=input log-prefix="Drop Input"
add distance=1 gateway=e.f.g.h1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set default-screen=stats read-only-mode=yes touch-screen=disabled
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=EAA
/system logging
add topics=dhcp
/system scheduler
add interval=1d name="Auto reboot - daily" on-event="/system reboot" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=mar/25/2018 start-time=06:30:00
  • update your router to 6.42.1
  • go to the “bridge1” interface, note the MAC address field and copy the value after that into the “Admin. Mac address” field.
Update will be done after working hours, I’ll let you know results.
Thanks,
Best regards!
You can do the setting on the bridge interface during day with little problems when you make sure the MAC is unchanged.
(maybe a down/up flap on the interface but normally no serious interruption)
So far no complaints from customer, problem seems resolved.
Thank You very much!!!
Best regards
