DHCP + Radius + Accounting
Hi all,
Can I do the accounting using radius of the traffic of my customers through the DHCP authentication?
I don’t use hotspot but I’m needing to know how much of bytes each customer is using and my customers don’t have fixed IP address, than I can’t creating a simple queue (the dhcp create one simple queue for each customer dynamically but the IP can change) for each customer and make a script to read the counters.
Best regards
Fabrício F. Kammer
unfortunately, no - you cannot obtain traffic accounting information directly from DHCP
maybe TrafficFlow may help you
Hi Chupaka, thanks for the reply!
The DHCP creates the simple queues dinamically. Can I use those queues to get the traffic and sent it to my mysql server?
If yes do you know can I do this?
Best regards
Fabrício
automatically - no…
anyway, TrafficFlow is quite enough ))
