dhcp + radius + hotspot
Hi!
I configure one hotspot server with radius.
I have a problem
If I set the client mac to the radius server work correct (create simple queue , assign ip addr to client ..)
but if the client mac not in radius config the client not have dhcp addr.
in the debug I see the temporary address but this not assigned to the client (not see in the ipconfig)
I set radius to dhcp,hotspot
set the dhcp and hostpot server use radius
the hotspot set to mac, http chap, etc login
hotspot debug:
_hotspot,debug server1: new host detected 00:02:2D:31:12:56/169.254.58.249 in 20-Mar 14:20:38.36 from 192.168.32.5
hotspot,info,debug 00:02:2D:31:12:56 (192.168.35.2): trying to log in by mac in 20-Mar 14:20:38.36 from 192.168.32.5
hotspot,debug 00:02:2D:31:12:56 (192.168.35.2): local user not found in 20-Mar 14:20:38.36 from 192.168.32.5
hotspot,debug 00:02:2D:31:12:56 (192.168.35.2): sending RADIUS authentication request in 20-Mar 14:20:38.36 from 192.168.32.5
hotspot,debug server1: dynamic host 00:02:2D:31:12:56/169.254.58.249 added, ip 192.168.35.2 in 20-Mar 14:20:38.36 from 192.168.32.5
hotspot,debug 00:02:2D:31:12:56 (192.168.35.2): Access-Reject from RADIUS in 20-Mar 14:20:38.96 from 192.168.32.5
hotspot,info,debug 00:02:2D:31:12:56 (192.168.35.2): login failed: invalid username or password in 20-Mar 14:20:38.97 from 192.168.32.5
_
I need the folowing working:
if the client mac in radius, set the ip addr with specified in radius and use the “net”
if the mac not in radius, set temporary ip addr and must logon in hotspot page to use the “net”
thanks &
Regards form Robit
