I am running a DHCP server on the RB1000 that uses an external radius server. I would like to be able to specify the password sent with the radius request like you can with the hotspot. This way I can use the same radius server to authenticate multiple services. Does anyone know if this is possible?
Thanks for the reply Chupaka. I may have asked my question wrong. My radius server configuration is working properly with the password specified under the radius menu. I am trying to send a specific User-Password value for authentication when using DHCP. When using the hotspot feature you can specify a “MAC Auth. Password” allowing you to authenticate based on the username (MAC address) and the password (whatever password you set under “MAC Auth. Password”). If I have multiple RouterBoards configured for hotspot, DHCP, or PPPoE using the same radius server, I will run into problems since I have usernames (MAC addresses) without passwords.
As far as I know you can’t specify much for DHCP RADIUS. You can, however, specify a default domain or realm for the DHCP instance of RADIUS and use that to separate out accounts on the RADIUS server.
