DHCP relay on CPE Bridge not working
Hi there,
I’m trying to setup a Wifi extender using a Mikrotik 951G-2HnD connecting to my Home Router(HR).
With no configuration I used the Wizard to setup a CPE in Bridge mode, so that I can use HR IPs.
My problem comes with the devices connected to the Mikrotik, as they’re not getting any IP from my Home Router. I added a DHCP Relay, and it shows its counter increasing on IP requests, but my devices get no ip.
What am I doing wrong?
Thanks in advance!
If by Wizard you mean Quick Set, I’m not sure what exact config it creates. But regular bridge is transparent for DHCP. You can try posting your config.
