DHCP Relay over GRE
I am trying to set a DHCP relay connection through a simple GRE tunnel.
The tunnel is established for days and I can ping the DHCP server through the tunnel but the DISCOVER is not reaching the DHCP server.
I was trying multiple things but without luck.
You might know something or a solution to solve this problem.
The other side is a CISCO router and my side is a Mikrotik device. This works with CISCO to CISCO flawlessly with ip-helper.
Honestly - I ran out of ideas.
Thanks,
Tom
Mikrotik’s DHCP servers do not listen at L3 interfaces.
Using DHCP relay does not make sense to me, but have done it before between 2 Mikrotiks
Can you post config of both MT and Cisco, maybe we can figure something out
