DHCP Relays
we have 2 routers (mikrotik). This routers are connected to main switch, we are using vlans. DHCP server is mikrotik too, lease is with server โ€œallโ€.
When We enable DHCP Relay for each vlan on each router, client will not bound - on server is offered for one secdond, then waiting.
When We enable only one DHCP relay on one router, weverything is fine.
Where is the problem ? :slight_smile:
Thank you
