DHCP request originating from loopback interface
Hi, I’m working on hardening my router… starting with defconf eliminating open ports, door banging brute force connection requests from the internet, etc.
I have found strange packets being dropped by the end of the input chain, seemingly originating from my own router:
Log: input: in:lo out:(unknown 0), connection-state:new proto UDP, 0.0.0.0:68->255.255.255.255:67, len 328
One request per second. Even shows on the interface:lo activity list.
As far as I understand, the loopback interface is asking for an IP address from the local DHCP server. From which point I do not understand… :slight_smile:
My MT router is connected to a cable modem, ether1 WAN DHCP client works fine. On the router the LAN side DHCP server is turned off.
LAN uses a dedicated rpi4 pi.hole gravity DNS and acting as DHCP server for all clients…
Please help, where to search?
Thx
Peter
Hi.
Maybe you are using the “internet detect” function, set all parameters there to “none”.
