DHCP server always red,Please Help --- solved
I tried created one more DHCP server(server2) with different SSID on my RB951g, Could you please help to advise why it's always red? my configuration file as below
BTW, I try to change wlan2 as bridge2, but still red.
sep/11/2014 08:54:42 by RouterOS 6.18
software id = 6WAP-4P60
add l2mtu=1598 name=bridge1
add l2mtu=2290 name=bridge2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge ssid=CDC
set [ find default-name=ether1 ] name=ether1_gateway
set [ find default-name=ether2 ] name=ether2_master
set [ find default-name=ether3 ] master-port=ether2_master
set [ find default-name=ether4 ] master-port=ether2_master
set [ find default-name=ether5 ] master-port=ether2_master
/ip neighbor discovery
set ether1_gateway discover=no
add authentication-types=wpa-psk,wpa2-psk,wpa2-eap eap-methods="" group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=DS12345678 supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=12345678
wpa2-pre-shared-key=12345678
/interface wireless
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:BA:D8:81 master-interface=wlan1 name=wlan2 security-profile=DS12345678 ssid=DS12345678 wds-cost-range=0 wds-default-cost=0
/ip hotspot profile
set [ find default=yes ] login-by=http-chap,trial nas-port-type=ethernet use-radius=yes
add name=dhcp_pool1 ranges=192.168.88.20-192.168.88.200
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=server1
add address-pool=dhcp_pool1 disabled=no interface=wlan2 name=server2
/ip hotspot
add address-pool=dhcp_pool1 addresses-per-mac=1 disabled=no idle-timeout=20h interface=bridge1 name=server1
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=no address-pool=dhcp_pool1 shared-users=5
add bridge=bridge1 interface=ether2_master
add bridge=bridge1 interface=wlan1
add bridge=bridge2 interface=wlan2
add address=192.168.1.63/23 interface=ether1_gateway network=192.168.0.0
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=www.rb951g.com
add address=192.168.88.10 name=www.radius.com
set enabled=yes
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
/ip hotspot ip-binding
add address=192.168.88.10 type=bypassed
/ip hotspot user
add name=1 password=1
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=192.168.88.0/24
add action=accept disabled=no dst-address=192.168.1.250
add distance=1 gateway=ether1_gateway
/ip service
set www port=800
/ip smb
set enabled=yes
/ip upnp
set enabled=yes
/radius
add address=192.168.88.10 secret=111 service=hotspot
/radius incoming
set accept=yes port=1700
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes primary-ntp=133.100.11.8
/system routerboard settings
set cpu-frequency=500MHz
/tool mac-server
set [ find default=yes ] disabled=yes interface=ether2_master
add
wlan2 doesn’t have an IP address.
wlan2 is already a member of bridge2.
Bind the server to bridge2 and it will work.
Additionally, bridge2 doesn’t have an IP address…
What’s your intention to have the same DHCP pool in two different bridges?
-Chris
Got it, Thanks for your information.
