DHCP Server - Any way to hand IP's out based on MAC address
Is there any way in RouterOS to give clients ip addresses based on their MAC address using wildcards.
For example:
Pool_1 - 10.1.1.0/24
Pool_2 - 10.254.254.0/24
00:01:02:::** - from Pool_1
All others from Pool_2
I found a post from 2009 that mentioned it but at that time was not possible other than using radius. A “filter” tab under DHCP server where you could set rules as such would be nice.
Can you seporate the DHCP networks by using vlans? If all of one Macs of one type are coming from one device like one AP then you probably could tag everything from that device.
If not then maybe you could get creative with bridges and bridge filters. At any rate I would bet that the trick will be seporating the layer2 networks by Mac not filtering the DHCP service.
This is something I need as well, and it would be really nice if RouterOS supported it. ISC does it via match lists very easily but I shouldn’t have to run a physical box on-site when we have routers that should have the capability.
