"DHCP server" checkbox unexpected behavior on QuickSet
In both Webfig and Winbox, there’s a “DHCP Server” checkbox under the LAN/WLAN block of the Quick Set panel. With a default install of ROS 6.2 on a RB951G, this box is unchecked by default. But I get DHCP-issued addresses on both wired (ether2 through ether5) and wireless (wlan). These seem to be coming from the default DHCP server running on bridge-local.
Is this the intended behavior of the checkbox in Quick Set, or is it a bug?
