DHCP server don't work when unsing VLAN and unifi to Mikrotik RB951U-2HnD
I have a Mikrotik RB951U-2HnD and a Ubiquiti UniFi AP LR indoor access point MIMO 2,4GHz. Both got the latest firmwares.
On RB951 I have setup WAN on ether1 and I have connect a switch 8 port and on ether2 which I have connect my pc’s and the unifi.
I want to use Vlan for my Unifi.
I have done all the configuration I found on the internet (DHCP servers, Pools, Addresses, Networks, etc) but when a device is connected to Unifi it doesn’t get an IP. If I disable the vlan id on Unifi it gets ip from local network dhcp server.
It seems the problem is the DHCP server of the Vlan.
Tried many configuration from many posts but no luck and I would like some help on this.
