I have a routerboard RB-532 that originally was setup as a spare router for an existing DSL line. We are switching DSL providers so I used this spare for the second path, changed the IP addresses, routing, DNS under IP options etc. Everything works great except…
Doing a DHCP server setup it shows the old DNS addresses, I update them along with the new IP gateway, pools and all appears to work.
Booting a XP computer with DHCP obtains a IP within the range, gateway is correct. Only it still assigns the old DNS server IP’s not the new ones??
Info on the RB-532 (the 128Mb version) running 3.20 firmware 2.18.
Ideas where the old DNS info is coming from and what I need to do to resolve this short of reformatting and reloading.
If you havn’t configured any DNS servers in the DHCP server settings I know it uses the system DNS settings instead. Perhaps that’s what’s happening for you as well.
