DHCP server help
First time posting so please bear with me…
I have a RB2011UiAS acting as a DHCP server for VDSL modems connected through a DSLAM. It seems the modem/routers are a little finicky about the DHCP responses they receive from the server. The modems send discover and request messages with the broadcast flag set to 0 but many times the server sends the offer and ack messages as broadcasts.
This is from the log:
00:50:22 dhcp,debug,packet Management_DHCP_Server received discover with id 1941582630 from 0.0.0.0
00:50:22 dhcp,debug,packet ciaddr = 0.0.0.0
00:50:22 dhcp,debug,packet chaddr = 3C:90:66:30:3F:78
00:50:22 dhcp,debug,packet Msg-Type = discover
00:50:22 dhcp,debug,packet Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address,Classless-Route
00:50:22 dhcp,debug,packet Relay-Agent-Info = 01-27-46-72-65-6D-6F-6E-74-4C-61-62-20-34-63-3A-61-63-3A-61-3A-63-33-3A-63-62-3A-64-36-20-65-74-68-20-32-2F-31-3A-31-30-30
00:50:22 dhcp,debug,packet Management_DHCP_Server sending offer with id 1941582630 to 10.202.0.99
00:50:22 dhcp,debug,packet yiaddr = 10.202.0.99
00:50:22 dhcp,debug,packet siaddr = 10.202.0.254
00:50:22 dhcp,debug,packet Msg-Type = offer
00:50:22 dhcp,debug,packet Server-Id = 10.202.0.254
00:50:22 dhcp,debug,packet Address-Time = 21600
00:50:22 dhcp,debug,packet Subnet-Mask = 255.255.255.0
00:50:22 dhcp,debug,packet Router = 10.202.0.254
00:50:22 dhcp,debug,packet Domain-Server = 10.202.0.254
00:50:22 dhcp,debug,packet Management_DHCP_Server received discover with id 1817835063 from 0.0.0.0
00:50:22 dhcp,debug,packet chaddr = 3C:90:66:67:35:90
00:50:22 dhcp,debug,packet Relay-Agent-Info = 01-27-46-72-65-6D-6F-6E-74-4C-61-62-20-34-63-3A-61-63-3A-61-3A-63-33-3A-63-62-3A-64-36-20-65-74-68-20-32-2F-33-3A-31-30-30
00:50:22 dhcp,debug,packet Management_DHCP_Server sending offer with id 1817835063 to 255.255.255.255
00:50:22 dhcp,debug,packet yiaddr = 10.202.0.100
This shows two different Discover messages from two identical devices. In one case the server responds with a unicast offer, in the other it sends a broadcast offer.
Running 6.41 right now but incremental upgrading from 6.35 to 6.41 all showed the same behavior. Attached is the config, it wouldn’t allow me to attach a pcap file showing the packets.
Any help here would be greatly appreciated.
Thank you very much.
LabConfig_1-14-18.rsc (2.92 KB)
According to RFC 2131:
If the broadcast bit is not set and ‘giaddr’ is zero and ‘ciaddr’ is zero, then the server unicasts DHCPOFFER and DHCPACK messages to the client’s hardware address and ‘yiaddr’ address.
The router is not consistently behaving this way.
Thanks.
No one has seen this before?
Or no one has had a problem with this behavior?
Thanks…
