Anyone a idea why my dhcp-server on vlan 201 doesn’t work. Also on other vlans it doesn’t work.
I want to plugin my laptop on Ether 9 (Vlan 201) and get an ip from the dhcp server
Its a CRS326-24G-2S+ that act as a router (yes i know
) and switch.
[admin@MikroTik] > export
# 2025-03-11 11:33:21 by RouterOS 7.18
# software id = R1M2-WJL4
# model = CRS326-24G-2S+
add name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name="vlan guest" vlan-id=209
add interface=bridge1 name="vlan iot" vlan-id=201
add interface=bridge1 name="vlan lan" vlan-id=200
add interface=bridge1 name="vlan mgmt" vlan-id=99
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.22.2-192.168.22.254
add name=dhcp_pool1 ranges=10.0.11.2-10.0.11.254
add name=dhcp_pool2 ranges=10.0.10.2-10.0.10.254
add name=dhcp_pool3 ranges=10.0.12.2-10.0.12.254
add name=dhcp_pool4 ranges=10.0.99.2-10.0.99.254
add address-pool=dhcp interface=bridge1 name="dhcp bridge"
add address-pool=dhcp_pool1 interface="vlan iot" name="dhcp iot" relay=\
10.0.11.1
add address-pool=dhcp_pool2 interface="vlan guest" name="dhcp guest" relay=\
10.0.10.1
add address-pool=dhcp_pool3 interface="vlan lan" name="dhcp lan" relay=\
10.0.12.1
add address-pool=dhcp_pool4 interface="vlan mgmt" name=dhcp1 relay=10.0.99.1
/port
set 0 name=serial0
/user group
add name=api policy="read,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!t\
est,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9 pvid=201
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24 pvid=99
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus2
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=ether9 vlan-ids=201
add bridge=bridge1 tagged=bridge1 untagged=ether24 vlan-ids=99
add bridge=bridge1 tagged=bridge1 vlan-ids=200
add bridge=bridge1 tagged=bridge1 vlan-ids=209
add bridge=bridge1 untagged=bridge1 vlan-ids=1
add interface=ether1 list=WAN
add address=192.168.22.1/24 interface=bridge1 network=192.168.22.0
add address=10.0.10.1/24 interface="vlan guest" network=10.0.10.0
add address=10.0.11.1/24 interface="vlan iot" network=10.0.11.0
add address=10.0.12.1/24 interface="vlan lan" network=10.0.12.0
add address=10.0.99.1/24 interface="vlan mgmt" network=10.0.99.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=0.0.0.0/24 dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=10.0.10.0/24 dns-server=10.0.10.1 gateway=10.0.10.1
add address=10.0.11.0/24 dns-server=10.0.11.1 gateway=10.0.11.1
add address=10.0.12.0/24 dns-server=10.0.12.1 gateway=10.0.12.1
add address=10.0.99.0/24 dns-server=10.0.99.1 gateway=10.0.99.1
add address=192.168.22.0/24 dns-server=192.168.22.1 gateway=192.168.22.1 \
netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall address-list
add address=10.0.10.0/24 list=UserNetwork
add address=10.0.11.0/24 list=UserNetwork
add address=10.0.12.0/24 list=UserNetwork
established,related,untracked
invalid
add action=accept chain=input comment="accept webmanagement" dst-port=80,8291 \
in-interface-list=WAN protocol=tcp src-address-list=ITN
add action=accept chain=input dst-port=8291 in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="defconf: accept ICMP" in-interface-list=\
!WAN protocol=icmp
add action=accept chain=input comment="vlan accept" in-interface="vlan iot"
add action=drop chain=forward comment="drop to management vlan" dst-address=\
10.0.99.0/24 src-address-list=UserNetwork
in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
/system clock
set time-zone-name=Europe/Amsterdam
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
