DHCP Server Invalid for Guest VLAN
I’m totally green on the VLAN but taking my first stab at creating a VLAN from scratch for my Ubiquiti AP. I had the VLAN working semi-correctly when added to a specific interface but when I add the VLAN on the Bridge and follow the same steps the DHCP Server comes out as Invalid. I prefer for the VLAN to be on the bridge instead of a specific port so there is no dependency on the AP to be plugged into a specific port.
 #    NAME                                 INTERFACE                                RELAY           ADDRESS-POOL                                LEASE-TIME ADD-ARP
 0    defconf                              bridge                                                   dhcp                                        10m
 1  I dhcp1                                VLAN_Guest                               10.1.200.1      VLAN_Guest_Pool                             10m
Is there something simple I’m missing here, it’s extremely vanilla:
add admin-mac=B8:69:F4:AB:32:8A auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=VLAN_Guest vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=VLAN_Guest_Pool ranges=10.1.200.100-10.1.200.199
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=VLAN_Guest_Pool disabled=no interface=VLAN_Guest name=dhcp1 relay=10.1.200.1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.1.200.0/24 dns-server=192.168.88.1 gateway=10.1.200.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
You can’t run DHCP server off an interface without IP address … and according to posted config interface VLAN_Guest doesn’t have IP address.
BTW, to avoid some possible odd problems, move LAN address from interface ether2 to interface bridge (IP settings should be done on bridge interface, not on bridge member ports).
Good catch. I knew a second set of eyes would help. Also moved the IP to the bridge as you suggested. Now I’m not getting an IP when hitting VLAN 200. Anything obvious?
/interface vlan
/ip hotspot profile
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.1.200.1/24 interface=VLAN_Guest network=10.1.200.0
/ip dhcp-client
/ip dns static
/tool mac-server
The VLAN setup is missing a lot. You might want to go through this tutorial, I believe it’ll make things more clear to you.
Thanks for the link. That’s literally where I started but I was trying to run those rsc files and it didn’t really leave the router in a happy state. I have a previous post about that.
I’ll try to diff those files against what I have. Oddly enough these steps seemed to suffice when I linked it to ether5.
The thing is that in your last posted config, the whole vlan config which should be under /interface bridge is missing … and if you want your RB to work with VLANs, there should be some.
/interface bridge vlan
I think that section is missing…at least.
/interface bridge vlan add bridge=bridge tagged=bridge,ether2,ether3,ether4,ether5 vlan-ids=200
Thanks. I’ll try to compare this against the golden reference in the other thread. Much appreciated.
