The hAP is now being given an address by the RB3011. So that much is again working. Devices are connecting to the hAP, but now they are not getting an IP. The log shows;
Mar/30/2019 21:04:30 wireless,info B0:FC:0D:##:##:34@wlan2: disconnected, received disassoc: sending station leaving (8)
Mar/30/2019 21:04:32 wireless,info B0:FC:0D:##:##:34@wlan1: connected, signal strength -59
Mar/30/2019 21:04:41 wireless,info 24:4C:E3:##:##:75@wlan1: connected, signal strength -48
Mar/30/2019 21:04:41 wireless,info CC:F7:35:##:##:93@wlan2: connected, signal strength -60
Mar/30/2019 21:05:03 wireless,info B0:FC:0D:##:##:34@wlan1: disconnected, received disassoc: sending station leaving (8)
Mar/30/2019 21:05:05 wireless,info B0:FC:0D:##:##:34@wlan2: connected, signal strength -69
Mar/30/2019 21:05:12 wireless,info 24:4C:E3:##:##:75@wlan1: disconnected, received disassoc: sending station leaving (8)
Mar/30/2019 21:05:12 wireless,info CC:F7:35:##:##:93@wlan2: disconnected, received disassoc: sending station leaving (8)
Mar/30/2019 21:05:12 wireless,info 84:D6:D0:##:##:64@wlan1: disconnected, received disassoc: sending station leaving (8)
Mar/30/2019 21:04:02 wireless,info 84:D6:D0:##:##:64@wlan2: connected, signal strength -66
Mar/30/2019 21:04:12 wireless,info 84:D6:D0:##:##:64@wlan2: disconnected, received disassoc: sending station leaving (8)
I’ve checked that:
- From Wireless> WiFi Interfaces, i can see that both wlan1 and wlan2 say they are in ap bridge mode.
- And from the terminal I get:
[paul@MikroTik hAP] /interface> /interface wireless print
0 name="wlan1" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:##:##:EB arp=enabled interface-type=IPQ4019 mode=ap-bridge ssid="Bree_IoT"
frequency=auto band=2ghz-b/g channel-width=20mhz secondary-channel="" scan-list=default wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
1 R name="wlan2" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:##:##:EC arp=enabled interface-type=IPQ4019 mode=ap-bridge ssid="Bree_IoT"
frequency=auto band=5ghz-a/n/ac channel-width=20mhz secondary-channel="" scan-list=default wireless-protocol=802.11
- From the Quick Set > Home AP Dual, I verified that under Local Address DHCP Server is un-checked (which I assume means bridge mode but I don’t see that anywhere).
[paul@MikroTik hAP] /interface bridge print
0 R name="bridge-wireless" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=66:2F:4D:##:##:72
protocol-mode=none fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m vlan-filtering=no dhcp-snooping=no
1 R ;;; defconf
name="bridgeLocal" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=B8:69:F4:##:##:E6
protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=B8:69:F4:##:##:E6 ageing-time=5m priority=0x8000
max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
[paul@MikroTik hAP] /interface> /ip dhcp-server print
Flags: D - dynamic, X - disabled, I - invalid
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 X dhcp1 bridgeLocal dhcp 10m
Anyone? Should there even be anything set up under dhcp-server if I want the RB3011 to be the server? It doesn’t seem to make any difference is it is disabled or not.
