Hi to everyone!
I’m new here and also new with routeros. Configuring for the first time my new Mikrotik hEX (RB750Gr3) was easy.
Not so assign a Static IP to my devices in my LAN netwrok.
To do this I followed two simple guides:
- How to change dhcp range
- DHCP Reservations
I changed the DHCP range to “192.168.0.50 - 192.168.0.254” and I assigned to 6 devices the following IP:
192.168.0.2
192.168.0.3
192.168.0.4
All is ok, but I can not do it for a single desktop pc (with Windows 10 Pro 64 bit).
When I try to assign to it a static IP (192.168.0.4 and yes I’m sure is not assigned for another device) the machine can not obtain anymore the IP and can not connect to the LAN: the status in winbox changes continually by “bound” to “busy”.
If I remove this entry in the Leases list, the pc obtain normally an IP and connect successfully to the LAN.
Tried several times: with or without “Client ID”, with or without “Use Src. MAC address”, but no way…
What is wrong? Why only this pc?
I don’t know what to do anymore.
