There are two networks on a same physical interface. How can I make that both networks can get ip addresses from MikroTik?
Your options are
- Split the networks into 2 physical interfaces going into your router
- Setup VLANs on the entire network to divide them
- Setup Static DHCP entries by MAC address
BTW this should be moved to General Networking section.
-Louis
thx
