Hi All,
Using a 960PGS
During initial config I added the desired settings and ticked the NAT option.
The router works in every other way except DHCP is red and nothing I have done so far will get it working.
I have tried multiple times defaulting the router but as soon as NAT is enabled DHCP dies.
Config is below. I can confirm all Ip details are valid, DHCP pool has been set up, DHCP assigned to bridge, DHCP IP details are valid.
Does anyone have any clue, this has driven me nutrs for some time.
# apr/04/2019 09:39:30 by RouterOS 6.44.1
# software id = VWEA-8241
# model = 960PGS
# serial number = SOMESERIAL
/interface lte
set [ find ] mac-address=XX:XX:XX:XX:XX:XX name=lte1
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] poe-out=off speed=100Mbps
set [ find default-name=ether3 ] poe-out=off speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=XXX.XXX.XXX.XXX-XXX.XXX.XXX.XXX
add name=dhcp_pool1 ranges=XXX.XXX.XXX.XXX-XXX.XXX.XXX.XXX
add address-pool=dhcp disabled=no interface=bridge name=defconf
/interface ovpn-client
add add-default-route=yes certificate=mycert.pem_0 cipher=aes256 \
connect-to=some.url.com mac-address=XX:XX:XX:XX:XX:XX name=\
ovpn-out1 port=XXXX profile=default-encryption user=myuser
/system logging action
add bsd-syslog=yes name=rsyslog remote=XXX.XXX.XXX.XXX remote-port=XXXX \
syslog-severity=info target=remote
add name=debug target=memory
add bridge=bridge comment=defconf interface=sfp1
add interface=lte1 list=WAN
add address=XXX.XXX.XXX.XXX/27 comment=defconf interface=ether1 network=\
XXX.XXX.XXX.XXX
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
add address=XXX.XXX.XXX.XXX/27 comment=defconf gateway=XXX.XXX.XXX.XXX netmask=27
set allow-remote-requests=yes
/ip dns static
add address=XXX.XXX.XXX.XXX name=router.lan
established,related,untracked
add action=accept chain=input protocol=icmp src-address=XXX.XXX.XXX.XXX/16
add action=accept chain=input protocol=udp src-address=XXX.XXX.XXX.XXX/16
add action=accept chain=input protocol=tcp src-address=XXX.XXX.XXX.XXX/16
invalid
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=\
through_vpn passthrough=yes src-address=XXX.XXX.XXX.XXX/27
add action=masquerade chain=srcnat disabled=yes out-interface-list=WAN
add action=masquerade chain=srcnat disabled=yes out-interface=ovpn-out1 \
add disabled=yes distance=1 gateway=ovpn-out1 routing-mark=through_vpn
add distance=1 dst-address=XXX.XXX.XXX.XXX/27 gateway=bridge pref-src=\
XXX.XXX.XXX.XXX scope=10
/snmp
set contact=me@my.com enabled=yes location=\
ROUTER_ID
/system clock
set time-zone-name=Australia/Sydney
/system identity
set name=ROUTER_ID
/system logging
add action=rsyslog topics=warning
add action=rsyslog topics=info
add action=rsyslog topics=critical
add action=rsyslog topics=error
add disabled=yes prefix=--- topics=debug
/system ntp client
set enabled=yes primary-ntp=XXX.XXX.XXX.XXX secondary-ntp=XXX.XXX.XXX.XXX
/system scheduler
add interval=1d name="Reboot Daily" on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jan/01/1970 start-time=00:10:00
add interval=15m name="Reset USB if VPN Down" on-event="interface ovpn-client \
monitor ovpn-out1 once do={:if (\$status != \"connected\") do= {:log warni\
ng \"VPN Link Down, resetting USB\"; /system routerboard usb power-reset d\
uration=20}}; :delay 120;" policy=\
start-date=jan/01/1970 start-time=00:00:00
/tool mac-server
/tool mac-server mac-winbox
