DHCP server, reserved IP
Hi everyone,
I would like to change the default DHCP server set in my Hex router.
I would like to
  1. change the network 192.168.88.0/24 to for example 192.168.92.0/24
  2. have reserved DHCP IP for specific MAC addressee
Is this possible with the ROS ?
Of course. Just change the network everywhere (you can export configuration to easily see all places where it is). And for reserved address, there’s either “Make Static” button for existing leases, ot you can create the entry manually.
