DHCP server?
Hello. Need help with a configuration.
Need a simple DHCP Server on port 1. No NAT. And uplink for remote management with public IP on port 4. Thankful for any help :slight_smile:
Think this is what you need;
  • create a bridge (dhcp_bridge])
  • add port 1 to dhcp_bridge
  • create an address/network for dhcp_bridge
  • create a pool for your DHCP addresses
  • create a dhcp server linked to this dhcp_bridge using the above pool
  • make a default route for trafic to dhcp_bridge (assume there is a default to the WAN defined)
Another device for BOTNet
Naah, remote management via VPN access.
