DHCP sever wokred but no internet access
I’m trying to do 2 SSID with VLAN each. The first ssid is for staff so no need the login page .The second ssid is for guest so that they need to login which are working fine. The problem is for the staff wifi can connected and get the Ip addrss but no internet access.. Please help me . newbie here
Please post your configuration.
/export hide-sensitive
I think you forgot add nat
It’s probably not NAT unless the default NAT configuration was changed.
