dijsil
November 20, 2018, 8:49pm
1
I have a mikrotik router (RG) that is working fine and I need to copy the configuration on another different model of mikrotik (RB952),
I have exported the configuration using the export file=filename,
opened in text file and copied the commands
Resetted the RB952 without a configuration
opened terminal and pasted all the commands
however I am not getting an ip address and in the dhcp server it is showing as red, below please find the configuration + screenshot.
add admin-mac=*** auto-mac=no name=bridge-LAN protocol-mode=\
none
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface eoip
add !keepalive mac-address=**** name=eoip-tunnel remote-address=\
10.0.0.7 tunnel-id=102
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
add authoritative=after-2sec-delay interface=bridge-LAN name=default
/ip hotspot profile
add name="DHCP Local" ranges=192.168.50.100-192.168.50.200
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool="DHCP Local" authoritative=after-2sec-delay disabled=no \
interface=ether5 lease-time=4h name="DHCP Local"
/ppp profile
add change-tcp-mss=yes name=PPTP-profile use-encryption=yes
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/interface pptp-client
add allow=mschap2 comment="VPN Connection to ****" connect-to=\
******** disabled=no name=pptp-**** password=\
****** profile=PPTP-profile user=****
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge-LAN interface=eoip-tunnel
add bridge=bridge-LAN interface=ether3
add bridge=bridge-LAN interface=ether4
add bridge=bridge-LAN interface=ether2
set discover-interface-list=discover
/interface l2tp-server server
set ipsec-secret=****** use-ipsec=yes
add interface=bridge-LAN list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=eoip-tunnel list=discover
add interface=bridge-LAN list=mactel
add interface=bridge-LAN list=mac-winbox
add interface=ether3 list=mactel
add interface=ether3 list=mac-winbox
add interface=ether4 list=mactel
add interface=ether4 list=mac-winbox
add interface=ether5 list=mactel
add interface=ether5 list=mac-winbox
add interface=wlan2 list=WAN
add address=192.168.50.1/24 comment="dhcp server" interface=ether5 network=\
192.168.50.0
add address=192.168.11.5/24 interface=ether1 network=192.168.11.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
ether1
ether1
add dhcp-options=hostname,clientid disabled=no interface=wlan2
add address=192.168.11.0/24 comment="default configuration" dns-server=\
192.168.11.5 gateway=192.168.11.5 netmask=24
add address=192.168.50.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.50.1
set allow-remote-requests=yes servers=*******,******
/ip dns static
add address=192.168.11.5 name=router
/ip firewall address-list
add address=***** list="Allowed DNS"
add address=**** list="Allowed DNS"
add action=accept chain=forward comment="default configuration" \
connection-state=established
connection-state=related
add action=accept chain=forward src-address=192.168.50.0/24
add action=accept chain=input comment="To allow winbox connection Everyone" \
dst-port=8291 protocol=tcp
"To allow winbox connection only DNS in Address lists" dst-port=8291 \
protocol=tcp src-address-list="Allowed DNS"
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
# no interface
add action=masquerade chain=srcnat out-interface=pptp-***
add disabled=yes distance=1 gateway=****.1
/ppp secret
add disabled=yes name=vpn password=*****
/system clock
set time-zone-autodetect=no time-zone-name=Europe/***
/system identity
set name="*****"
/system ntp client
set enabled=yes primary-ntp=138.96.64.10 secondary-ntp=78.140.251.2
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
anav
November 21, 2018, 1:25am
2
Where is the IP dhcp-pool, IP address, IP server network for this entry??
or did you create the above rule by error?
You also have three listing for the same bridge under interfaces listing, not sure if thats normal/okay?
You also have multiple listing for interfaces for ethports, not sure if thats normal/okay?
You have the 192.168.11.0/24 network as belonging to eth1 but there is no such etherport listing in your interfaces?
Hello
A DHCP server is red if it’s assigned to a slaved interface (I.e. ether port under a bridge) but it doesn’t look like it.
I’ll Go with Anav’s idea: I’m seeing the bridge and ether5 in the same interface list; not sure…
Envoyé de mon LG-H873 en utilisant Tapatalk
Anav pointed it out right - /ip dhcp-server needs correct /ip address on the same interface as well as properly configured /ip dhcp-server network and /ip pool in order to run correctly.
However, only missing /ip address will make the DHCP server red. Missing /ip dhcp-server network and /ip pool will prevent it from working as expected but it won’t make it red. (unless you missed them on purpose)
Putting /ip dhcp-server on slave interface will also make it red, but there will be clear description, that it was mis-configured on slave interface and due to that it is running on master interface (so it is like warning that running state is different than configuration)
dijsil
November 21, 2018, 5:56am
5
I am still new to networking and mikrotik, it should connect to another mikrotik using a vpn connection and wish to use ports as per below
port 1 is for the gateway (static ip from isp not configured yet)
port 2-4 for VPN (gets ip through vpn)
port 5 for local dhcp
I still cannot understand, if I copied the configuration from a working mikrotik how come I am getting an error on this one ? shouldn’t the export command exports all configuration that the mikrotik has ?
Jotne
November 21, 2018, 6:45am
6
Not sure if anav have read the complete post, I can see all of the config.
ethernet 5 config
192.168.50.0
It has IP, DHCP and its not connected to the Bridge, so should be OK. But Is the port online, some consented to it?
If not, it will be red.
dijsil
November 22, 2018, 8:47pm
7
ok managed to get internet from port 5 (using dhcp) however when connecting to ports 2-4 I am not getting ip address from the dhcp on the remote vpn router
checked the vpn connection and it is connected however cannot ping the other side router 192.168.11.1 and not getting ip from dhcp on remote location
(from the config above I changed the dhcp from .50.0 to .60.0)
ingdaka
November 23, 2018, 9:02pm
8
As you can see from italic font of ether5 it indicates that port is notconnected!
dijsil
November 24, 2018, 7:53am
9
with regards to port 5 it is working fine and getting ip from the local dhcp server.
My issue (last issue I hope) is that the pptp connection is connecting to a vpn connection to another mikrotik router and I wish that I get an ip from the vpn server in Site A. The pptp connection is connecting with local ip 10.0.0.3 and remote 10.0.0.4 and I can ping both ips however I cannot ping the devices on the other side from site C from the mikrotik and also my pc is not getting ip from the vpn server
Site A - mikrotik with vpn server
Site B - mikrotik with vpn client connects with site A
New site C - connects with site A
Below please find my current config:
# nov/24/2018 08:46:38 by RouterOS 6.43.4
# software id = 075F-13J8
# model = RouterBOARD 952Ui-5ac2nD
# serial number = ****
add admin-mac=**** auto-mac=no mtu=1500 name=bridge-LAN \
protocol-mode=none
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether5 ] name=ether5-local
/interface wireless
set [ find default-name=wlan1 ] disabled=no hide-ssid=yes mode=ap-bridge \
ssid=MikroTik wireless-protocol=802.11
set [ find default-name=wlan2 ] disabled=no hide-ssid=yes mode=ap-bridge \
/interface eoip
add !keepalive mac-address=*** name=eoip-tunnel remote-address=\
10.0.0.3 tunnel-id=103
add name=WAN
add name=LAN
add name=mactel
add name=mac-winbox
/ip hotspot profile
add name="DHCP Local" ranges=192.168.60.100-192.168.60.200
add name=vpn ranges=192.168.90.2-192.168.90.255
interface=ether5-local lease-time=4h name="DHCP Local"
/ppp profile
set *FFFFFFFE local-address=192.168.90.1 remote-address=vpn
add allow=mschap2 comment="VPN Connection" connect-to=\
/snmp community
set ipsec-secret=**** use-ipsec=yes
add interface=ether1-gateway list=WAN
add list=LAN
add interface=ether5-local list=discover
add interface=ether5-local list=mactel
add interface=ether5-local list=mac-winbox
add interface=bridge-LAN list=LAN
add address=192.168.11.8/24 interface=ether2 network=192.168.11.0
add address=192.168.60.1/24 comment="Giving Local internet" interface=\
ether5-local network=192.168.60.0
add address=192.168.11.7/24 interface=ether2 network=192.168.11.0
/ip cloud
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
192.168.11.8 gateway=192.168.11.8 netmask=24
add address=192.168.60.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.60.1
set allow-remote-requests=yes servers=***,***
/ip dns static
add address=192.168.11.8 name=router
add action=accept chain=forward src-address=192.168.60.0/24
disabled=yes dst-port=8291 protocol=tcp
protocol=udp
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="masq. vpn traffic" out-interface=\
ether1-gateway
add action=masquerade chain=srcnat disabled=yes out-interface=pptp-****
add disabled=yes distance=1 gateway=213.165.184.1
/ppp secret
/system clock
/system identity
set name="*** ***"
/system ntp client
set silent-boot=no
/tool mac-server
dijsil
November 24, 2018, 3:50pm
10
issue solved. Had to create eoip tunnel on the vpn server and assign it to the bridge.
