DHCP to DNS
I’ve been using this DHCP LEASE to STATIC DNS entry script and I notice that it takes the hostname from the dhcp lease to form the dns entry.
But, some of my devices (mostly iOT-type things) have identical hostnames like: espressif and Emporia.
Would it be possible to check if an entry with that name but with a different MAC address already exists in the DNS list and if so, append a “-2” or something to the end of the hostname part in the dns entry (so it actually gets added)?
Thank you.
# SPDX-License-Identifier: CC0-1.0
:local domains [:toarray "76.local"]
:local dnsttl "15m"
:local magiccomment "automatic-from-dhcp (magic comment)"
:local activehosts [:toarray ""]
:foreach lease in [/ip dhcp-server lease find] do={
 :local hostname [/ip dhcp-server lease get value-name=host-name $lease]
 :local hostaddr [/ip dhcp-server lease get value-name=address $lease]
 :if ([:len $hostname] > 0) do={
    :foreach domain in $domains do={
      :local regdomain "$hostname.$domain"
      :set activehosts ($activehosts, $regdomain)
      :if ([:len [/ip dns static find where name=$regdomain]] = 0) do={
        /ip dns static add name=$regdomain address=$hostaddr comment=$magiccomment ttl=$dnsttl
      } else={
        :if ([:len [/ip dns static find where name=$regdomain comment=$magiccomment]] = 1) do={
          /ip dns static set address=$hostaddr [/ip dns static find name=$regdomain comment=$magiccomment]
:foreach dnsentry in [/ip dns static find where comment=$magiccomment] do={
  :local hostname [/ip dns static get value-name=name $dnsentry]
  :if ([:type [:find $activehosts $hostname]] = "nil") do={
    /ip dns static remove $dnsentry
This is beyond my capabilities.
I’m thinking that if code can be inserted as follows, then different hosts with the same hostname can be added to the static DNS list:
      } else={
 *****IF /ip dns static name=$regdomain ALREADY EXISTS, APPEND A 5 DIGIT RANDOM NUMBER to $regdomain and proceed
It’s conclusive: This is beyond me.
I have the following gobbly-gook:
:local domains [:toarray "212.local"]
:local dnsttl "100m"
  :local macaddr [/ip dhcp-server lease get value-name=mac-address $lease]
      } else={
        :if ([/ip dns static find where name=$regdomain] = $hostname) | ([/ip dhcp-server lease find where address=$hostaddr] = $macaddr) do=(
		  :set regdomain=("$hostname", "-1")
          :/ip dns static add name=$regdomain address=$hostaddr comment=$magiccomment ttl=$dnsttl
          else={
