DHCP use Wildcard MAC to select pool?
Is there any way to use a MAC wildcard to select a different IP pool? For example, we’d like to be able to put any device with a 0a:00:3e:::* MAC address in a distinct IP pool. (that’s the OUI for motorola canopy gear, this would let us utilize DHCP for client radios in bridge mode but have them in a different subnet than the end-users’ routers or PCs)
j
Not with the RouterOS DHCP server. ISC’s reference DHCP implementation should be able to do this by matching the vendor identifier option.
This is a feature that I’ve asked for in the past. I’m casting my vote for it here again. :slight_smile:
for now, it’s possible only with RADIUS…
Just to clarify your post, does the MAC listed in radius have to be specific or can it be done thru a wildcard entry somehow like 0a:00:3e:::*?
I would love this option.
+1
This depends on your radius server (not MT).
I am using Freeradius. Does it support wildcard macs? Time to do some digging.
maybe something like
        attr_rewrite my_super_parser {
                attribute = User-Name
                searchin = packet
                searchfor = "^00:BE:EF:.*$"
                replacewith = "00:BE:EF"
                ignore_case = no
                new_attribute = no
                max_matches = 1
                append = no
in “modules” block, then add that module in “authorize” section
and after that add a record for user “00:BE:EF”
Cool that sounds like the way to go. I have another follow-up question along this line if you will bear with me.
Now, let’s assume I have two wireless cards in the AP (wlan1 & wlan2) which are not bridged together but instead have two different real IP subnets. I also want to overlay a private IP subnet onto each wlan card for managing of the transparent wireless devices (00:BE:EF:::*) . I want to hand out these private IP’s to these devices via the radius attribute Framed-Pool. Since there are two separate subnets, hence two different pool names, how would you accomplish this?
Eric
huh… I’m not familiar with FreeRADIUS…
two interfaces = two DHCP servers. so you need to set Framed-Pool depending on Called-Station-Id (it’s DHCP server name)
