DHCP via GRE tunnel
I’m trying to make a GRE tunnel between two office, and it works, the problem i got that i must have the same subnet in both sides, which means same one DHCP server and same network in the both sides.
It works with EiOP tunnel but I wold se if it should works too with GRE.
Any idea?
You can only use the tunnel EoIP (layer2)
OR PPTP-L2TP with BCP
