DHCP - WAN interface without DNS addresses
Is it possible to say which parameters while DHCP-releasing/renewing is allowed?
I do not need DNS addresses given by the DHCP from my ISP.
Si just set the dhcp client not to use the dns settings and make the independent dns settings manually.
I disabled “use peer DNS” and “use peer NTP” for DHCLP client for wan-interface but the status page shows the primary and secondary DNS server.
With 6.32.3 and even after reboot?
Yes, also with 6.33.3.
Strange. You should make supout and send it to support. It may be some bug. Let us know the results.
Ok, I will contact the support - but this buggy behavior is simple to reproduce.
