dhcp,warning dhcp1 offering lease without success
hello community
In this oportuniad I consult a specific case to see if I get a solution to their experience.
The case is:
Base Box 5 v6.29.1
With 03 APs TP-Link-841N
AP occasionally blocked and log shows the error:
" dhcp,warning dhcp1 offering lease without success"
The common factor here is that just happens to Apple ( iMac , Macbook , Iphone, etc ) equipment
If anyone have any similar case please can share their experience , to see if I can solve the problem.
Thank you
Update with the latest RouterOs and update the bios.
Watch it on my website how to update the bios.
In Dutch but check out the screen shots
http://www.wirelessinfo.be/index.php/mikrotik/pages/rbupgrade
This error do you get when the devices are too far from the access point.
There is a bad communication between AP and client
Do you use characters in your SSID equal _-/?
If so, don’t do that.
Hi Thanks for the recommendation , just general knowledge. Why do you recommend not using the characters ( _ and -) SSID ?
Certain devices can’t handle it
Sorry for my bad Englisch but try to help you
Do not worry just my excuse me I’m Spanish and I do what I can with the English .
Thanks for your help I’ll do you recommend I upgrade . Then I will write here if the problem is solved.
I made the Upgrade by versions 6.30,6.31 and even 6.32rc6 , and all give the same error. The only solution so far has worked is to downgrade to version 6.23 this version works well .
¿ Someone have any observations, experience with it ?
