dhcp warning ??
Hi…
what reasons can be for this log message…
dhcp,warning,info,debug dhcp1 offering lease 1.1.1.52 for 00:13:CE:71:F3:11 without success
any idea ??
thanx
gerd
hello all
am also getting same error lately,
dhcp,warning dhcp1 offering lease 10.0.11.148 for 00:C0:CA:39:12:0B without success
dhcp,warning dhcp1 offering lease 10.0.11.14 for A8:7B:39:DC:90:62 to 06:25:82:10:03:D7 without s
uccess
dhcp,warning dhcp1 offering lease 10.0.11.86 for 2C:A8:35:DF:3B:F9 to 06:25:82:10:03:D7 without s
uccess
any advices…
The DHCP server offered a lease but the client didn’t take it. The two most likely causes are that either the DHCP interval timed out just in time for the server to process the request for the client, but for the client to already have given up, or for another DHCP server being faster and serving the client first.
…thats Explains alot… thanx alot for the reply
How do you get it to stop if it’s constantly sending that message and always the same MAC?
Don’t allow that client on your network. This isn’t a problem with the server, the server is doing what it’s supposed to.
SOLVED.
Not sure how to do code so someone else can translate if they like but here’s what worked for me:
IP → DHCP Server → Leases → Add new → General=“Pool_Name”, MAC Address=“MAC address of desired blocked”, Server=“Name of DHCP Server failing”, Block access = yes, Address List = Black-list
Hope that helps someone else
hi all i get same problem it happens in windows 7 and 8 and vista because ipv6 when i disable ipv6 it work will but for people who i did not know where they are i can not fix
Hi sir, i would like to ask if this is working im having a same problem with my network
server-LAN offering lease 192.168.63.252 for 20:76:93:54:6B:14 without success
