I am kind of a newbie with router OS, I need assistance on how to disable dhcp on a specific eth port but keep the port active to pass internet on the devices connected to it by assigning static IPs to the devices.
Basically I would like to disable DHCP for connections using Ethernet but I would like keep DHCP for wifi, is that possible?
“both eth ports and Wlan are in the same bridge” \
