purpose to enable server dhcp for wlan as well as ether4 outlet
did: created bridge1 for port ether4 and wlan1
result: dhcp1 invalid within dhcp server error(red) while bridge eth and wlan RB751
any fix? thank you
any fix? thank you
Pretty sure you meant to put dhcp on the bridge, not ether4.
running dhcp-server set interface ether4
how to serve dhcp-server via wlan aswell?
i cannot follow “put dhcp on the bridge, not ether4”
how? since nothing to bridge/ port on dhcp-server as interface
hao,
you have to move dhcp-server from ether4 to bridge1, it’s simple, and this dhcp server release ip to eth and wifi interface automatically. For understand reason I suggest to add address to bridge1 like a gateway; in example, if the network on the bridge is 192.168.10.0/24 you can put in bridge 192.168.10.1
A.
hi andre/ jhheider, thanks for your help
i assigned dhcp interfce to bridge IO physical ether/ wlan… its working fine/ status resolve ok
Perfect!![]()
