I testing an RB450G with RoS 5.18 on DSL and IPv6. While I configured dhcpv6 client on the router and it works but as soon as I reboot the router or turn on then dhcpv6 client doesn’t make ipv6 pool:
[admin@rtr.test] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1 1500 D4:CA:6D:39:92:43 enabled
[admin@rtr.test] > /interface pppoe-client print brief
# NAME MAX-MTU MAX-MRU INTERFACE USER PASSWORD PROFILE
0 R dialer1 1492 1492 ether1 x@y.z password default
[admin@rtr.test] > /ipv6 dhcp-client print
Flags: D - dynamic, X - disabled, I - invalid
# INTERFACE STATUS PREFIX EXPIRES-AFTER
0 dialer1 bound 2001:738:800:860::/60 9m56s
[admin@rtr.test] > /ipv6 dhcp-client export
# jul/02/2012 13:05:48 by RouterOS 5.18
# software id = 0000-0000
/ipv6 dhcp-client
add add-default-route=no disabled=no interface=dialer1 pool-name=stateless_DHCPv6_pool pool-prefix-length=64
[admin@rtr.test] > /ipv6 pool print
Flags: D - dynamic
# NAME PREFIX PREFIX-LENGTH
[admin@rtr.test] >
In the log I see this:
jan/02/1970 01:00:07 system,info router rebooted
jan/02/1970 01:00:13 pppoe,ppp,info dialer1: initializing...
jan/02/1970 01:00:13 pppoe,ppp,info dialer1: dialing...
jan/02/1970 01:00:14 interface,info ether1 link up (speed 100M, full duplex)
jan/02/1970 01:00:14 interface,info ether3 link up (speed 100M, full duplex)
jan/02/1970 01:00:15 interface,info ether2 link up (speed 10M, half duplex)
jan/02/1970 01:00:18 pppoe,ppp,info dialer1: authenticated
jan/02/1970 01:00:18 pppoe,ppp,info dialer1: connected
jan/02/1970 01:00:18 system,info dns changed
12:50:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:51:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:52:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:53:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:54:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:55:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:56:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
12:57:08 dhcp,error updating pool6 expire time failed:std failure: unknown id (4)
<snip>
If I release dhcpv6 client then works again:
[admin@rtr.test] > /ipv6 dhcp-client release 0
Flags: D - dynamic
0 D stateless_DHCPv6_pool 2001:738:800:860::/60 64
[admin@rtr.test] >
Any idea what is the problem?
cheers,
oreggin
