/ipv6/dhcp-client adds a dynamic blackhole route for the delegated prefix. I want to preemt this route with my own route and firewall rules that use ICMPv6 errors.
Previously you could disable it, but starting with 7.20 it’s no longer possible: failure: cannot modify dynamic route created by a different owner
I reached out to support and they recommended looking at /routing/settings/dynamic-in-chain. It’s barely documented and I’m not sure how to use it.
Could someone give an example of either disabling the default blackhole route or changing its distance?
You can add two routes with longer (+1) prefixes and they'll be picked before the blackhole route.
For instance, your ISP gives you 2001:db8:85a3:8a00::/56. You can then add two routes with destinations 2001:db8:85a3:8a00::/57 and 2001:db8:85a3:8a80::/57.
I only look at the top of the linked page, but there is a bug in MakeIP6PrefixMask. You use 0. 1, 3, 7, f but the correct sequence should be 0, 8, c, e, f instead for 0000, 1000, 1100, 1110, 1111.
For example :put [$MakeIP6PrefixMask 18] produces ffff:3000:: but it should be ffff:c000::.
Also the checks at the beginning of StructureIP6AddressCommon will need to be adjusted starting from 7.21. Because in 7.21 the conversion from ip6-prefix with :toip6 will succeed and the result is no longer of type nil.
