DHCPv6-client
Hello, I’m in my house and I have the modem that belongs to my ISP and I put a mikrotik on port 1. In dhcpv6-client, I do not receive an IPv6 address or prefix, debugging, mikrotik receives a NoAddrAvail message. When I put my notebook directly on the ISP, I get the IPV6 address
add admin-mac=6C:3B:6B:FA:AC:9F auto-mac=no comment=defconf name=bridge-lan \
    protocol-mode=none
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether5 ] poe-out=off
set [ find default-name=sfp1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n channel-width=\
    20/40mhz-Ce country=brazil disabled=no distance=indoors hide-ssid=yes \
    mode=ap-bridge multicast-helper=disabled security-profile=Christian ssid=\
    Christian wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=3 band=5ghz-onlyac \
    channel-width=20/40/80mhz-eCee disabled=no frequency=auto hide-ssid=yes \
    mode=ap-bridge security-profile=Christian ssid=Christian-ac wps-mode=\
    disabled
/ip hotspot profile
set enabled=yes
/ip settings
set rp-filter=loose tcp-syncookies=yes
/ipv6 settings
set accept-router-advertisements=yes
/interface detect-internet
set wan-interface-list=WAN
add comment=defconf interface=bridge-lan list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge-lan network=\
    192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.245 client-id=1:84:a4:66:1a:b1:ad mac-address=\
    84:A4:66:1A:B1:AD server=defconf
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
/ipv6 dhcp-client
add add-default-route=yes interface=ether1 pool-name=pool-ipv6 \
    pool-prefix-length=127 request=address
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    established,related,untracked
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/16
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    connection-state=invalid
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes other-configuration=yes
/ipv6 route
add check-gateway=ping distance=1 dst-address=2000::/3 gateway=\
    fe80::562f:8aff:fe1f:ce78%ether1
Are you sure that there is a DHCP server? Most likely provider is giving out stateless address and you do not need dhcp client to receive this address.
See description here:
https://wiki.mikrotik.com/wiki/Manual:IPv6/ND#Stateless_address_autoconfiguration
