DHCPv6-PD Support?
Greetings, all.
So, I’m looking at alternatives to our current bandwidth management and authorization service and decided to try my hand at MikroTik’s User Manager. I got DHCP MAC authorization for v4, but I’m struggling trying to get IPv6 to work correctly with the User Manager. I’ve tried a couple of methods, both using the MAC address and the DUID of the endpoint in the User Manager and adding a static binding in the IPv6 DHCP Server bindings. What I’ve noticed is…despite having use-radius=yes set on the IPv6 DHCP server, it doesn’t make any calls to User Manager. Is this a bug or is there something that I have set wrong?
My network layout is as follows (using GNS3 to simulate):
WAN router/DHCP(4 and 6) server (R1) connected to a switch (S1), User Manager plugged into switch, another router/DHCP (4 and 6) relay (R2) connected to the switch, endpoint router/DHCP (4 and 6) client (R3) connected to R2. This is an adequate representation of my live network.
Thank you for your time.
Did you find a solution for this?
Thanks,
IPv6 and Mikrotik are still having huge gap to bridge.
Hope Mikrotik Team will concentrate more on IPv6 Modules…
You can use a dual stack, check out this article from one of our senior Network Architects
https://stubarea51.net/2018/09/14/wisp-design-an-overview-of-adding-ipv6-to-your-wisp/
