Hi Forum,
this is my first post in this forum and I am well aware that there might not be a straight solve-all answer to my questions.
First I would like to explain my setup.
I am running a WISP with ~20 clients and CCR1009 at the core.
I using PPPOE for client connectivity and user-manager on the core router.
My outbound bandwidth consists of the following lines:
- 2x dedicated (one customer only) 16Mbit/1Mbit DSL lines
- 1x shared (all other customers) 100Mbit/12Mbit Cable (DOCSIS3.0) line
Unfortunately the cable line employs (enforces) the use of an additional router with NAT (FritzBox Cable). To avoid having to many NAT stages I disabled NAT in the core router a using static routes inside the FritzBox.
This all is working fine in principle.
I should mention, that I also have a Linux box where the core router is and where all the uplinks are located.
Now I observe the following:
- I can download a file (over WLAN) from my Linux box with the full speed the WLAN link provides (3MByte/s for example).
- I can download a file from the internet to my Linux box (over 1Gbps Ethernet link) with full speed of the cable uplink (10 MBytes/s)
- When I try to download a file from the internet over WLAN, I get fluctuating transfer rates of about 1MByte/s.
I experimented with the following:
- Disabling various firewall rules (no change in throughput)
- Disabling queues completely (no change in throughput)
- Creating a OVPN tunnel (also over WLAN), that is bridges into the local subnet of the FritzBox directly (3MBytes/s as desired)
So my questions are:
- Can you give me any pointers to look for/ to read up on/ to try out?
- Is there any problem with pppoe links and bandwidth beyond 1MByte/s?
- Can I “prove” that the bottleneck/problem is not caused by the core router?
Thanks for all hints in advance.
