Hi Experts,
Hope all of you are well.
I have a problem and can’t seem to get to the bottom of it, the only explanation is maybe fasttrack broke or only working 50% after recent updates? (Or possibly my FW Rule Order???)
When I originally swtiched over from DSL (20Mb/2Mb) to Fibre (1000Mb/100Mb), I could only get just over 200Mbps with RB2011UiAS-2HnD. I then enabled fast track which made a huge difference and managed to get over 800Mb/97Mb. This was July 2017.
I regularly update my network / PC equipment and update my my Mikrotik as and when updates become available, currently I am on 6.40.4
Yesterday we were doing some excessive downloads and noticed the download speeds max out on ± 430Mbps and started doing some troubleshooting.Bypassed the RB2011 and connected PC directly to fibre and we get 943Mb/97Mb (http://beta.speedtest.net/result/6709745290) which indicates no problem on the ISP / Internet side.
It does not matter if I disable all rules, only enable Fasttrack rules, etc, the internet download speed stays at ± 430Mb/97Mb when going through the Mikrotik router.
Any suggestions will help, please!!
/ip firewall filter> print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 chain=forward action=fasttrack-connection connection-state=established,related
2 ;;; Allow Established, Related connections
chain=forward action=accept connection-state=established,related log=no log-prefix=""
3 ;;; Allow New connections from Bridge
chain=forward action=accept connection-state=new src-address-list=LocalLAN log=no log-prefix=""
4 X chain=forward action=accept connection-nat-state=dstnat in-interface=ether1 log=no log-prefix=""
5 ;;; Allow Established, Related connections
chain=input action=accept connection-state=established,related log=no log-prefix=""
6 ;;; Allow access to router from LAN
chain=input action=accept connection-state=new src-address-list=LocalLAN log=no log-prefix=""
7 ;;; PPTP VPN Incoming
chain=input action=accept protocol=tcp in-interface=ether1 dst-port=1723 log=no log-prefix=""
8 ;;; GRE VPN Incoming
chain=input action=accept protocol=gre in-interface=ether1 log=no log-prefix=""
9 ;;; Drop Invalid Connections
chain=forward action=drop connection-state=invalid log=no log-prefix=""
10 ;;; Default Forward Drop Rule
chain=forward action=drop log=no log-prefix="Drop-Forward"
11 ;;; Default Input Drop Rule
chain=input action=drop log=no log-prefix="Drop-Input"
/ip firewall nat> print
0 chain=srcnat action=masquerade to-addresses=<WAN Address> out-interface=ether1 log=no log-prefix=""
1 chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix=""
2 D ;;; upnp <Internal Addr>: Skype UDP at <Internal Addr>:22756 (3941)
chain=dstnat action=dst-nat to-addresses=<Internal Addr> to-ports=22756 protocol=udp dst-address=<WAN Addr> in-interface=ether1
dst-port=22756
3 D ;;; upnp <Internal Addr>: Skype TCP at <Internal Addr>:22756 (3941)
chain=dstnat action=dst-nat to-addresses=<Internal Addr> to-ports=22756 protocol=tcp dst-address=<WAN Addr> in-interface=ether1
dst-port=22756
/ip firewall mangle> print
chain=prerouting action=passthrough
1 D ;;; special dummy rule to show fasttrack counters
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting action=passthrough
3 X chain=prerouting action=mark-routing new-routing-mark=Guest-Traffic passthrough=no src-address=192.168.169.128/25 log=no log-prefix=""
4 X chain=prerouting action=mark-routing new-routing-mark=Mweb-NS passthrough=no protocol=icmp dst-address=196.2.16.3 log=no log-prefix=""
5 X chain=forward action=mark-connection new-connection-mark=LargeDownloadConn passthrough=yes protocol=tcp dst-address=!192.168.168.15
connection-bytes=5000000-0 in-interface=ether1 time=6h-20h,sun,mon,tue,wed,thu,fri,sat log=no log-prefix=""
6 X chain=forward action=mark-packet new-packet-mark=LargeDownloadPacket passthrough=no connection-mark=LargeDownloadConn log=no log-prefix=""
7 X chain=forward action=add-dst-to-address-list protocol=tcp dst-address=192.168.168.0/23 address-list=LargeDownload address-list-timeout=5m
connection-bytes=15000000-0 in-interface=ether1 log=no log-prefix=""
/interface bridge settings> print
use-ip-firewall: no
use-ip-firewall-for-vlan: no
use-ip-firewall-for-pppoe: no
allow-fast-path: yes
bridge-fast-path-active: yes
bridge-fast-path-packets: 232
bridge-fast-path-bytes: 88107
bridge-fast-forward-packets: 0
bridge-fast-forward-bytes: 0
/ip settings> print
ip-forward: yes
send-redirects: yes
accept-source-route: no
accept-redirects: no
secure-redirects: yes
rp-filter: no
tcp-syncookies: no
max-neighbor-entries: 8192
arp-timeout: 30s
icmp-rate-limit: 10
icmp-rate-mask: 0x1818
route-cache: yes
ipv4-fast-path-active: no
ipv4-fast-path-packets: 0
ipv4-fast-path-bytes: 0
ipv4-fasttrack-active: yes
ipv4-fasttrack-packets: 2018084
ipv4-fasttrack-bytes: 1917646388
I made sure all conditions are met for fasttrack/fastpath
Please help, very frustrating, if you need any further info, please do not hesitate
