if anyone knows about creating a tunnel between mikrotik box that one of the box behind NAT router please help me and point me in the right direction
Regards
Regards
You have to configure the nat-router to pass the tunneling-packets
through.
Here is how packets of ipip looks like:
http://www.ietf.org/rfc/rfc2003.txt?number=2003
If there is only one ipip tunnelling device behind nat you simple
pass all Pakets with protocol=4 to the MT box behind NAT.
The other MT uses the NAT-Address as peer.
Regards,
Stefan
Sorry to bump this up but when you say pass all Pakets with protocol=4, do you mean that we simply port forward TCP port #4 to the local private IP address?
ip nat inside source static tcp 192.168.xx.xx 4 interface FastEthernet3/0 4
Is that sample code good for a CISCO router?
