Did someone make cisco ISG functions on MRouterOS?
May be useful links on this theme?
Please, specify the features you need most.
most of all I need
  • to change speed limit on pppoe interface without disconnecting pppoe session
  • to make different limit speed on different direction (src/dst IP) - for example I need torrent traffic in home LAN limit by 5Mbit/s - and internet traffic 1Mbit/s - can I do it via radius AV Pairs?
Can I do it with RouterOS?
Thanks for answer!
automatically it is not possible.
It is possible by static queue configuration, not by RADIUS.
All profiles stores on billing - how mikrotik (future NAS) will know which queue to apply on a user?
For PPPoE user per username.
I understood this I use pppoe and all queus send to ROUTEROS via AV pair Rate-Limit += “2M 2572k 1536k 8 8 1536k”,
How can I sent to RouterOS
that all traffic in (192.168.0.0/16 and 10.0.0.0/16) queue must be 10M/10M
all other (INTERNET) queue must be 1M/1M
So on each pppoe interface I would have two queue - for LAN and Internet
via RADIUS AV pairs can I do it?
No, you can do it by static queue configuration (not by RADIUS).
ok, thanks for answer
another question
eth1 - WAN-Inaternet with NAT
eth2 - for radius aaa
eth3 - LAN interface abonet net
I have sim 600-700 pppoe and 15 min interval for alive (update packets) -
when I see in RouterOS log “radius timeout” ROS on LAN interface (ether3) freezes
I solve this problem in two ways
  1. Reboot -ROS - all is ok after reboot
  2. or just disable or enable ether3
I sent many suppout.rif on 3.30 version
I can sent today one more time when it will crash again
I dont understand why ether3 freeze and do not answer on arp request - after disable and enabling this interface - everything is ok
Why you are not support 3.30 version
Another bug
server boot up
if I disable pptp server and then enable it - only 24 pptp user can log in
if I dont disable and then enable pptp server - everything is ok all pptp user can log in
I need ISG FUnction for PPPOE users FOR dirrent sites Decrease Creadit
