Difference and priority of IPv4 and IPv6 firewall filter?
I have tried to find the answer of my question in the documentation for Packet Flow but was not successful:
In which order are the packages processed with respect to IPv4 and IPv6?
For example, I would like to separate two VLANs, regardless if IPv4 or IPv6. My idea was to block forwarding on interface layer.
Would the firewall filter for IPv4
add action=reject chain=forward in-interface=vlan7 out-interface=vlan16 reject-with=icmp-admin-prohibited
also work for IPv6 traffic or do I need a separate entry in IPv6 firewall filters:
/ipv6 firewall filter
Are both (IPv4 and IPv6) filters are processed for every kind of traffic or is there a strict separation between IPv4 traffic and IPv6 traffic? If both are handled, in which order are they processed?
You need separate filters for different IP versions (IPv4 and IPv6).
The router looks at the version of the packet received (in the Layer 2 header) and applies the relevant filters for that version.
So, IPv4 packets only traverse IPv4 filters and IPv6 packets only traverse IPv6 filters.
