difference b/w NTH and PCC load balancing
Dear,
Any one please help me out to solve my question. Actually I have 1 Lan and 2 Wan Setup in my office. I want load balancing in ROS 5.18. Please suggest me which option is suitable for me.
actually some time my 1 WAN link goes down and I dont want my user’s to get disconnect, or my WAN traffic automatically divert to 2nd WAN. in this scenario which load balancing is suitable for me. I have also setup Proxy cache server.
You can try with following command. You have to change interface name and ip address as per your Router.
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
Thanks alot Syed Abu Saleh,
but pls tell me is this NTH or PCC load balancing?
It’s PCC load balancing.
AOA,
How are you. I am using RB 750 Router board. I have use 2 different isp and do that PCC script for load balancing and load merging. I face a problem when i try to upload something Filezilla FTP. My FTP not working when both Isp are working. So i disable one ISP then do the uploading. Can you please tell me what should i do to solve this problem or how can i exempt some ips from the the PCC rule. So theses ip only use one isp for uploading. I thing u understand the problem.
As per your mail please remove following mangle first.
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/2 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
Dear Robotics909,
You have to use following code:
/ip firewall address-list
add address=172.16.0.2 list=usere-exempted-from-pcc
/ip firewall mangle
add action=accept chain=prerouting disabled=no src-address-list=user-exempted-from-pcc
JazakAllah Dear Syed Abu Saleh,
I found very usefull information and help. May Allah Bless you. Ameen
Dear abu saleh,
please confirm me, will my proxy work in PCC load balancing with 1 Lan and 2 WAN?
Yes, Proxy will work also.
Hi all.
How many PCC can i have in the same box..?
I need to have PCC for my LAN and also PCC for my cache server on a different port with different subnet..?
Can it be done with 2 PCC ..?
Bests regards.
Yes, you can
hello, i back this tropic after long day finished. i am already problem on this. i am also using loadbalancing with pcc . for ftp problem you suggest to add those rules.
my question is, will i remove my mangle old two rule and add those two ? or i will keep my loadbalancing as it is and add those rules which you adviced ?
another, if i load those two rules, will this continue loadbalancing for my ftp download ?
hope you will help.
best
hope you will help.
best
Do you have any problem now?
what about UserManager ?
will this PCC work well with UserManager?
I used it but the problem all traffic are going through WAN1 only !!!
Dear,
Any one please help me out to solve my question. Actually I have 1 Lan and 3 Wan Setup in my office. I want load balancing in ROS 5.18. Please suggest me which option is suitable for me.
actually some time my 1 WAN link goes down and I dont want my user’s to get disconnect, or my WAN traffic automatically divert to3nd WAN. in this scenario which load balancing is suitable for me. I have also setup Proxy cache server.
