Hello there,
First post here.
I used to use a PPPOE provider and had several firewall/NAT rules setup. At the time, the rules used PPPOE as the “income” port", because Ether1-gateway didn’t seem to work.
Now I changed to a DHCP provider (no authentication) and it I had to change all that stuff.
Question: Why Ether1-gateway doesn’t work in PPPOE connections, if it used the Ether1 port? What’s the difference between PPPOE and Ether1-gateway?
