Different behaviour between file script and shell
Hello
Is it right that the same script doesn’t work if imported from a .rsc file, but works if copy-pasted?
  :global var 123
  :put ("Var contains ".$var)
is there any difference if you open them for editing?
is there difference if you print it?
No, if I open and save it, there’s no difference: it doesn’t work.
About printing the environment, this is my script
  :global var 123
  :environment print
And this is the output
/import test_global_vars.rsc
var=123
Var contains
Script file loaded and executed successfully
